gluing diamond plate to painted drywall
mojokat
coma toast
All walls. Orignal owners demanded 3/4 inch drywall and 2x6 framing on ALL walls. All walls filled with insulation as well.
sounds like a little overkill, but I'll bet that place is tight as hell. Gotta provide some serious piece of mind, too.
Yellowdog
New member
My house is made of 3/4inch drywall and 2x6 framing. My new house is better built than your piss filled bucket :myhorse:
double brick. ..6 inch baseboards.. 3/4 inch hardwood over 1/2 inch plywood glued and screwed every 6 inches over pine planking..all copper pipes..all heavy electrical wiring
synonymous
Better than you.
Want to come measure my drywall :touche:
I don't doubt you because I'm aware of the product's existence. That being said, I would not think it worth the cost to do an entire house with it. 5/8" is good enough (although it takes 2 sheets of 5/8" to equal some of the characteristics of the 3/4 stuff if what you have is what I'm thinking of)
